Page 2 of 2 1 2
#43240 07/18/02 01:36 AM
F
F
Try out the steeda tri-ax shifter. Verry nice! Cheaper to because you have a choice of getting a knob with it or not. Here are some pics. That blue piece of metal is a spring thing to assist 2nd to 3rd shifting, yes it helps.
Well i was just "fazzman"
01 MTX Focus rainforest green
borla, esslinger udp, steeda tri-ax shifter, eibach pro kit springs and dampers, tint, sterio stuff , and some interior work
#43241 07/18/02 02:41 AM
Originally posted by Po-Jay:
Okay, I may have been on some substances this weekend, but let me give a more intelligent explaination of what I meant. (It was a long weekend)
Okay, I retract the longer statement and replace it with Uncomfortable and Awkward. The stock shifter has a different pivot point angle (that I am positive of)... The B+M is set up to be a more comfortable as well as shortend throw.
Even if I am on crack, I think that you could see that the solid construction and aluminum pivot point are a worth while improvement. It is disgusting that Ford attempted to build a "Sports Sedan" worthy of an entry level Bimmer, yet left the sloppiest shifter and linkage that they could produce, in place. Cut down or not, it is still a crappy set up... IMHO.
I'd have to respectfully disagree. I bought a B&M back when it was $70 (maybe 2 years ago?), and aside from the material (aluminum), a shorter upper arm, and slightly thicker shaft, it seemed no different from a cut-down stock shifter. Some shifters shorten throw by adjusting the length of the lower arm, but as far as I could tell, the B&M isn't made this way. The quality is also arguable, as many people have already reported that the lower pivot ball for the cable linkage has snapped off due to inadequate welding.
Personally, I installed it and disliked having to reach so far down for the shifter. By shortening the upper arm, it also decreases the leverage, making it more difficult to shift. Needless to say, I sent mine back. IMHO, the stock shifter feels fine after you use the tranny cocktail.
-Louis
1998 Black E0 #3826, lightly modded
#43242 07/18/02 03:00 AM
If you don't mind putting a fist through your head unit every once in a while :p wink
Ryan
Latest Mod: Mirko Splitter
#43243 07/21/02 05:54 AM
....Personally, I installed it and disliked having to reach so far down for the shifter. By shortening the upper arm, it also decreases the leverage, making it more difficult to shift. Needless to say, I sent mine back. IMHO, the stock shifter feels fine after you use the tranny cocktail.
Maybe I have gorilla arms, but is is exactly where I need it to be. The OEM felt like I was in a Big Daddy Roth, Rat-Fink cartoon. My shift knob was around my ear! laugh
To each their own. That Steeda shifter looks nice!
Po-Jay
Ghetto Mods Galore!
Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap-
Blood,Sweat,Tears
Do I hear the Fat Lady singing?
98 E0 Silver Frost (Is there any other color?)
172HP 149TQ W/Bad A/F Mix
Page 2 of 2 1 2
