#43230 07/13/02 09:51 PM
i saw that someone posted awhile back about the focus short throw shifter working on a contour..just wondering if anyone has tried it on their tour?if so how easy is it to install?and how well does it work? there are several on ebay now for about $70,made by obx..anyone have any info on these?
98 silver frost svt
no cats/magnaflows
kkm true-rev
white hvac
ford blue calipers
more to come!!
#43231 07/14/02 01:08 AM
The 98+ Contour MTX uses the same shifter as the Focus. So, any shifter for a Focus should fit a 98+ CDW27 (including Cougar).
#43232 07/14/02 02:52 AM
I have one on my car, but you should save the $70 and just cut about 2 inches off the stock one. That is the only difference I could see.
Ground Control Coilovers
Koni Adjustable struts
Sub-frame connectors
Slotted rotors
Carbon Fibre pads
Stainless Steel Braided line
KKM Intake
Pro-Flow Mass-air Meter
22mm rear sway bar
Polyurethane motor mount inserts
#43233 07/14/02 09:03 PM
The B+M Short Throw has a solid aluminum pivot point. The stock shifter does not. The short throw has a much more solid feel. *Do Not* cut the stock shifter! The throw angle is different on the B+M and it makes your throw shorter. If you cut the stock shifter you will increase your throw distance, and in effect lengthen your shift time. It will be a shorter shifter but not a short throw shifter. (function vs. fashion)
Po-Jay
Ghetto Mods Galore!
Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap-
Blood,Sweat,Tears
Do I hear the Fat Lady singing?
98 E0 Silver Frost (Is there any other color?)
172HP 149TQ W/Bad A/F Mix
#43234 07/15/02 12:31 PM
Eh Jason, were you on drugs this weekend?
Explain this one to me?
I cut mine down 2" and I can definitely tell you the throw is shorter. And I am $140 richer too!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#43235 07/15/02 01:57 PM
Ditto here.
#43236 07/15/02 02:57 PM
I see you have not yet discovered the secret of GEOMETRY..
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
#43237 07/16/02 04:46 PM
I cut mine down 2" and I can definitely tell you the throw is shorter. And I am $140 richer too![/QUOTE]
Okay, I may have been on some substances this weekend, but let me give a more intelligent explaination of what I meant. (It was a long weekend)
Okay, I retract the longer statement and replace it with Uncomfortable and Awkward. The stock shifter has a different pivot point angle (that I am positive of)... The B+M is set up to be a more comfortable as well as shortend throw.
Even if I am on crack, I think that you could see that the solid construction and aluminum pivot point are a worth while improvement. It is disgusting that Ford attempted to build a "Sports Sedan" worthy of an entry level Bimmer, yet left the sloppiest shifter and linkage that they could produce, in place. Cut down or not, it is still a crappy set up... IMHO.
Oh, and thanks for calling me out Stazi! Now everyone is aware of my habits. laugh (How the hell are you, BTW?)
Po-Jay
Ghetto Mods Galore!
Blood,Sweat,Tears
#43238 07/16/02 05:43 PM
Jason - I am pretty bloody good, lately despite some SERIOUS shiz going down in my life. I am overdosing on a 6ft blonde that rocks every part of my world, and I am loving it!
Oh and the SVT has never looked or driven better, and it can only get better ~ turbo/quaife/flywheel etc!
I know that the B&M feels nice, but I think it beacause it has a heavier shaft, thus making the shift effort easier - that's what it seems like to me, and I drove a B&M eqipped Tour last night, so it is fresh in my mind. I am going to experiment with adding weights to the highest point possible on my cut down shifter to see if it helps.
Regards,
Anastazi
#43239 07/16/02 06:30 PM
Jason - I am pretty bloody good, lately despite some SERIOUS shiz going down in my life. I am overdosing on a 6ft blonde that rocks every part of my world, and I am loving it!....
What is this??? Stazi is becoming a "kept-man"??? Say it isn't so! lol. Good Luck!
Po-Jay
Ghetto Mods Galore!
Blood,Sweat,Tears
