To all you that have this problem with the brake and ABS light spots reversed heres what I mean:
Pic #1 Here's the soulution:
Take a dremal and cut a path between the 2 pieces (Between the ABS light and the brake light - BUT DON'T do it if you have ABS) and funnel the light from the origional brake light position to the new brake position with some aluminum foil or other reflective surfaces, and it'll look like this:
Pic #2 You will have to tape something over the ABS light so the leftover light from that shaft wont reflect into the ABS light - so you wont confuse the next person who buys your car.
Hope this helps someone!
