Posts: 20 |
No, of course it shouldn't. But my real question is that I heard about people removing the padded-matt from the hood to decrease amount of engine heat. Can someone tell me if this a good idea and if it makes a significant difference or if it has any disadvantages? Thanks.
On a personal note, did you know that if you keep giving kittens food, they'll just keep eating it? Its kind of fun to watch.
Posts: 198 |
I removed the mat that under my hood and I experienced less heat soak issues with my open element air filter. I believe that someone has documented the reduced intake air temperature without the hood blanket. Do a search for more info. The only other thing that I noticed was an increase in engine noise without the mat. Another two cents worth from me. Mike
1996 SE MTX, Desert Violet Blaupunkt Munchen, Dunlop Sport 5000s, Ray McNairy's THFix, custom air filter, Magnecor wires, Redline D4 tranny cocktail, 9005 lo-beams SVT-size front rotors, EBC Greenstuff pads all around
Posts: 79 |
I think without the mat to insulate, the engine bay will disperse the heat better. I also heard that the heat can discolor your hood after a while.
my 0.02
Old - 95.5 SE with lot's of mods. New - 98 Black SVT with few mods.
Posts: 897 |
It may discolor it...but let's face it, it's the bottom of your hood. You don't drive with it up. (At least I hope you don't) I pulled mine off and did notice it running a little cooler, but I changed my intake pipe and have since changed the waterpump and thermostat, so it could be any of the things mentioned. $.02 contributed
1998 T-Red CSVT (1492 of 6535) Born on 5/30/97 KKM 4.6L TB with custom "Throttle Optimizer" Bassani Exhaust NP-Tuning Sniper Intake Pipe Fog Light Mod with 885's Clear Corners Stereo - Oh Yeah!
GOLIATH - RIP 6/14/02
Posts: 1,428 |
Posts: 147 |
I removed mine. No bad side effects yet.......
Posts: 85 |
I have a 99 misty and it doesn't have one...? I heard about removing it for wieght & cooler temps but at the same time have heard that it drops down onto your engine incase of a fire - but then again mine didn't come with one. :p
Posts: 816 |
My 96 doesn't have one either.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 79 |
Originally posted by Dandridge: It may discolor it...but let's face it, it's the bottom of your hood. You don't drive with it up. (At least I hope you don't)
$.02 contributed I meant it might discolor the paint on top of the hood as well as the inside. I suppose it would take a LONG time, but I imagine it could happen. The one other thing I always worried about was the hood making contact with the battery terminals. Then again I have an aftermarket battery. Is this my 0.03?
Posts: 515 |
1999 and 2000 was decontented. Mostly noise abatement.
Hood shouldn't discolor from heat.
Most "low end" cars don't have it.
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
