Sent you the pics, Monkey. Thanks a-lot.
As for mods, I'm probably going to put the car on a strict diet, tearing out ALL the dead weight. Looking at a 75 or a 100 shot NOS, with the appropriate fuel system upgrades. I believe all I need are larger injectors, since it already has an upgraded ignition (Crane Cams Fireball & Coil), high pressure oil pump, and a rising rate fuel pressure regulator. Head was recently rebuilt and new piston rings are being installed right now along with a balanced crank.
Osigma, I will be in touch shortly. Thanks for the support, guys. Can't wait to post the AFTER PICS!!!
Oh, and Bad Apple, putting a GM Small block into a Z is distasteful and redneckish. Suggesting it on a FORD Forum is sacrilegious!
