Under the front of your tour there is a plastic cover that goes under the radiator. After you remove that you will have plenty of space in the front. In the rear you should have enough room as long as you mount the tube above your mufflers tip.
John 1996 Ford Contour 2.0 Liter Turbo 5spd/ Pioneer 6.5" Television / DEH8000 CD Player/ Darkened Tail Lights/Shaved Emblems/ 17" Ultra Nocturno Rims 205/40-17's/ Custom Painted Cowl,Wipers, And Mirror Mounts/ Shaved Front Tag Holes And Window Squirters/ High Flow Catalytic Converter/Ford 9mm Spark Plug Wires/ Custom Exhaust Catalytic Back/Hyper White Lights/ Superchip/K&N Air Filter/Shortened Fubo Antenna/Billet Rear Antenna/ BNMotorsports White Face Gauge W/ Red Numerics And Matching HVAC Panel/H&R Coil Over Springs.
