#43010 07/07/02 06:03 PM
X
X
I owned a v6 contour two years ago. then I drove the svt just last night. I am thinking of buying it from my friend, but I want to know how well the svt v6 responds to forced air induction,is the engine built like a tank or will it throw rods with a supercharger (10+lbs), and does the performance generated by an sc make it worth doing.
You can find all that by searching. Have fun.
-Antonio
99' SVT
86' Toyota Pickup Beater - Tha Daily Driver
some of the later SVT's can NOT be supercharged because of the fuel return system and programming
embedded in the CPU and PATS
1999 Black SVT #2639/2760 on 08/11/1999; w/18" OZ Racing Superleggera's, Yoko Paradas.
MSDS Headers,Quaife LSD, Borla,KKM,chipped,DMD,Baer 13" Track rotors.
Lowered/HR and Koni's; HPP RSB
Lee Offline
No but they can be turbocharged...
Lee Cox
In life begins responsability...
Project Car
but i sure as heck wouldn't run 10+ psi of boost...compression on SVT engines is way too high for that.
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=50;t=000167 wink
~~~~~~Mike~~~~~~
Silver 2000 Contour SVT
# 1200 of 2150
X
X
Thank you guys. It is almost imposible to find anything on the web about upgrading the contour svt...I called up svt directly and they had no clue as to what the engine could handle.
And also I know how much of a ***** it can be to answer ignorant questions, but when answers can not be found this is my last resort.
