Posts: 142 |
has anyone done this? any info and/or pics would be appreciated.
-1988 Bronco II: Blue and silver with 8 shades of rust. The system costs more than the vehicle  -1999 SVT Contour: Silver Frost, tinted windows, stock for now... -------- "Never slap a man that's chewin tobacco"
Posts: 2,683 |
WHY? Very unnessasary.Actually Ive never heard of a car with a hydralic e-brake,wouldnt be a e brake anymore.It would just fail with the other brakes then you would have no backup.Then again The tours have a PARKING brake and not a e-brake. :rolleyes:
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Posts: 1,053 |
Originally posted by -HWCM-: The tours have a PARKING brake and not a e-brake. Good point, why do folks call it the emergency brake ??
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course." #9 - Hitting .400 for ever "Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez "The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Posts: 142 |
why do folks call it the emergency brake ?? so they dont have to call it a P-brake and why? for rallying of course. almost every WRC car has a "parking brake" ( :rolleyes: ) to whip the back end out on tight turns. they lock the back wheels up better than stock parking brakes. i think it would be fun to slide around dirt/gravel/snowy turns.
Posts: 174 |
if your hydraulic brakes go out you still have the mechanical handbrake left, hence the term emergency brake. wouldnt parking brake or emergency brake be appropriate terms?
THIS CAR IS F***ING COOL!
bone stock for now...
Posts: 93 |
ah no, most rally cars do not have a parking brake, in fact they mostly have a quick change (usually lever action) brake baising valve. It goes from about ~90% front brake torque to ~20% front brake torque. (have you tried pulling your E/P-brake hard enough to actually stop your car?) Oh wait, be careful, if you get it into a spin its not my fault
Geoff C. Turner
99 Black SVT -mine 99 Blue SE V6 ATX -mom's 96 Black SE MTX -sister's
Posts: 2,683 |
Originally posted by geoffct: ah no, most rally cars do not have a parking brake, in fact they mostly have a quick change (usually lever action) brake baising valve. It goes from about ~90% front brake torque to ~20% front brake torque. (have you tried pulling your E/P-brake hard enough to actually stop your car?) Oh wait, be careful, if you get it into a spin its not my fault I have,if its dry out the car is to heavy and it does nothing just slowed me down a little.Maybe the AVS's are just to sticky?
Posts: 3,934 |
Standard all-seasons, and my brake won't stop mine either. It will acually only lock them up if I am at a full stop and try to drive. If I am moving, its just to slow me down. :rolleyes:
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 149 |
speaking of the e-brake......... Is there ANY way to set it up?? Mine no longer holds sufficiently on a hill and has a large amount of handle movement.....
I've heard they cannot be adjusted... but haven't looked for myself....
I know I need brake pads soon... maybe thats it..
Thanks Jason
Posts: 818 |
According to my Chilton's manual (chapter 9-25), the parking brake cable is self adjusting: "The parking brake cable is adjusted by operating the parking brake control handle several times." Which to me says that if your handle has too much movement and "operating the...handle several times" doesn't help, the cable has streched and you need to replace it. But I defer to the experts here....
2000 Contour SE Sport T-Red MTX, Mystique rear dome light, Blau Florida cd.
