Posts: 1,195 |
Originally posted by JVitolo: Try the thermostat W3RD
97 Zetec MTX Sport Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam) Dual Fiamm air horns Mk1 Mondeo Clear corners(and yes I made them fit....) Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com AIM: AphexTwinGrin
Posts: 117 |
I saw that once on my car. Just before the water pump died and the head gasket blew. Diffinately not a good sign, I would be scared to drive it much without finding out whats wrong.
'95 Mercury Mystique LS Praire Tan w/ Tan Leather MTX, Moonroof
Posts: 1,041 |
Yeah I had the same problem with my Waterpump. 60,000 or so miles.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 563 |
if you say the hood wasn't even hot check your sensors could be a grounding problem. Also how your starter doing does it ever have a probelm hanging? I haave all the guages peg in my mustang and it turned out to be the relay on the starter. Just some ideas.
Dustyn Red 1998 SVT E1 95 Mustang GT Yeah there both slow New ram clutch for sale Sho shop pullies and belt for sale 30 bucks
Posts: 627 |
Move only if there is a real advantage to be gained...when you move, fall like a thunderbolt. -Sun Tzu, The Art of War '98 SVT E0 Superchip Y-pipe KKM filter custom 2.5 cat back exhaust UDP linux fish
Posts: 3,934 |
That pic was taken with the engine off, but the key was on. Everything is functioning like it should, I am suspecting the coolant temp sensor.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 3,934 |
Just so everyone knows what happened... The engine is fine. The ground for the guage cluster had come loose, causing faulty readings. :rolleyes:
· Jon Miconi
Posts: 1,428 |
That looks so much like my car, racing a GTI, when the water pump let go..
..Man, you 2.0 guys are lucky for that, one less scary thing to worry about!
Posts: 3,950 |
That is scary!
Posts: 195 |
Just put tape over it, Outa site outa.....
