Posts: 3,934 |
Thats brutal! I have had that happen before though. My old GM threw the braking material off of the backing plate. I got to drive home with the e-brake. The next day the auto parts store replaced the pads and rotors for free.  It probably helped a little that I was working at said store.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 5,805 |
Ryan,didn't we discuss the 'other potential probs' with your car when you had the clutch put in........ ;)Found it Work Order # 67360.....'points noted during strip down *Front & rear motor mounts/'shock,all show signs of wear and will need replacement over next few monts*All tires are low on tread and close to 'wear bars'*W/pump and alt drive belts should be replaced over next couple of months(cracks/wear)*Front brake pads show signs of uneven pad wear on inner pad,both sides,suggest new pads in spring*...!!!!!what more can I add!
Posts: 4,528 |
Haha Ryan just got scolded by the principle!
Posts: 168 |
I bet if you spun that rotor backwards with a needle to it you would hear satanic messages.
Ryan M. Taylor 1996 GL V6 ATX Desert Violet {__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __} http://rmtaylor.webhop.org AIM: Vinnland990
Posts: 2,729 |
Everyone needs to take a deep breathe. No, Stazi we didn't check the pin. Steve, the new brake stuff is from Stazi anyhow, I just didn't have the money yet when we were at his house. Terry, I did exactly what your work order said and I've began replacing those things in the spring (now). I have the stuff for the back. Andy W, I do regular maintenance checks, so did Ford. Spatt, yeah I have been taking it real easy on the new brakes. Todras, yeah...it always sucks getting told by "The Man"  Me, back to work now.
Posts: 761 |
Those rotors look like they have more grooves than a 45!  I just replaced my rotors BTW
Posts: 2 |
I could beat that, my 93' Grand Caravan the left from brake pad was worn to the metal so the brakes were metal on metal i would say for a good 100+ miles, i didn't even want to look at what it looked like so i just had someone else do the job...i do bad maitnence (sp)so i asked for it
Posts: 2,729 |
Originally posted by Wan A Tour: I could beat that, my 93' Grand Caravan the left from brake pad was worn to the metal so the brakes were metal on metal i would say for a good 100+ miles, i didn't even want to look at what it looked like so i just had someone else do the job...i do bad maitnence (sp)so i asked for it I don't think that's beating it...? If you take a closer look, thats what happened to me too....metal on metal. I went well over 100 miles like that though. And yes, I am braging for those of you wondering.
