#42852 06/27/02 04:19 PM
I was wondering what gauges to get for my SVT. I'm looking at the autometer white faced, ultra light gauges at summitracing.com
Which parameter(s) would be most appropriate for our cars?
Oil Pressure: 0-100, 0-150, or 0-200 psi
Oil Temp: 100-250F or 140-300F
I'll be getting an A/F gauge, too.
Thanks!
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
#42853 06/27/02 05:56 PM
F
F
Derek - Go with oil pressure 0-100, Oil Temp 100-250....Get a Mechanical Oil Pressure guage and an electric temp guage. As for the paint for the pod.....I don't know, but I am sure Marhyde makes something....Might want to find someone else who has done the research better then me for a perfect matching paint....What about Brad SQPlus?
Chad Williams
chad5160@excite.com
'99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
#42854 06/28/02 10:27 PM
chad, thanks man. those are the parameters I've decided on...(CEG was down, had to do research elsewhere!)
I'll go search for paint now that the boards are up. laugh
Mi Coche
#42855 06/29/02 01:33 AM
Yeup, I had a mech oil pressure, electric water and volts.
Just did SQPlus' and he used mech oil, volts and A/F. Came out beautifully.
I bought some paint from the local shop, just took in the stock A Pillar and matched it up as close as possible. Came out PERFECT. Brad didn't like the texture of his so he lightly sanded it and it came out very nice.
HTH
John
#42856 06/29/02 04:45 PM
Yeah, I'll probably sand mine down, too. I see that autometer has an electric oil pres. gauge, too. There's a oil pressure sensor ?near the oil filter? and I was thinking I could tap into that using the electric gauge. Would that be easier than doing a mech gauge?
If mech is better/easier, where did you tap into for the mech oil pressure gauge?
Finally, where should I tap into for oil temp?
Thanks. smile
Mi Coche
#42857 06/29/02 08:20 PM
F
F
Terry Haines
Member # 1375
Member Rated:
posted June 29, 2002 04:03 PM
Most of the electric senders are too big to mount in the main oil gallery on a Duratec,can be mounted on a remote oil filter head if you want electric...
Chad Williams
chad5160@excite.com
#42858 06/30/02 05:53 PM
There is actually an allen head plug that you can take out on the driver side of your engine block. You can plug a T-fitting in and put both your oil pressure and oil temp senders into this.
If this doesn't work it's Icey Mikes fault. He told me smile
99 "sleepy" SVT
#42859 06/30/02 06:00 PM
That plug is in the cylinder head and might as well be a million miles from the main oil gallery....the head is NOT a good place for an oil press sender...in or as close to the main oil gallery or main pressure feed is...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#42860 06/30/02 09:38 PM
thanks everybody...mechanical it is. close to mail gallery it is. laugh
Mi Coche
#42861 07/01/02 03:29 PM
Hey Terry, where should I tap into for oil temp? Same place as pressure?
Edit: just looking at summit...the phantom series has an electric oil temp gauge from 100-250F. the mechanical is from 140-280F. 140 is kinda high, isn't it? Will the electric gauge work? confused
Mi Coche
