I did mine LIM and UIM after 90k and then after 100k. They were just as bad after 90k as after 100k. I couldn't get much of the gunk below the LIM where the valves are. I was afraid of it dropping into the cylinders, yes I did use a shopvac.
I will do this every 6 month from now on.
Berryman's (B12?) from Autozone is by far the best, Gunk, STP, and another generic can't compare.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
