COBM Offline OP
I'll be cleaning my LIM and UIM next week but I need to know how to disconet the fuel rail. I checked the Ford cd and it calls for a special disconet tool. First Do they sale this tools to the public if not is there some other way around this? Ihave to replace the O rings on th eincjector since I notice a small fuel leak on one of them.
any advice will be apraciated
"You can turn a engineer into a sale man but, you can not turn a sale man into an engineer"
"I have walk to the valley of Honda and death for that I should not fear no V-tech"
99 cougar,SVT manifold convertion, Tranny upgrade by Haines Motor sports (Quaife lds, Fidanza flywheel, and Clutch Master Stage 3 clutch) 18" Axis Se7ends,GC coiovers,sho sho Y pipe,Wilwood4 piston brake kit
they should sell it at your local autommotive store. ask the workers for a fuel line separator tool.
E
E
Is your fuel system returnless? If so you could just un-bolt the Fuel Pressure Sensor(it's not really a regulator) from the rail and slide it out. If it is the return style, you then have two of these lines coming off the rail and would then require a special disconnect tool(the second line has no bolts). They are very inexpensive, a cheap one is made by Lisle Corp. and sells for under $15. It is probably available from any quality auto parts store.
...Ed
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
COBM Offline OP
it a return fuel syst will they sale this tool at the dealer? the ford Cd calls for two kinds of this tools.
Fuel Injection Supply Manifold ? Vehicles without Returnless Fuel System (234500)
Special Service Tool(s)
Disconnect Tool, Spring-Lock Coupling
310-D004 (23-039)
310-D005 (23-039)
are they the same ?
thanks
COBM Offline OP
I got the tools I found them at Sears
$9.99 Is incledible how this little platic tools
save you so much trouble
thank for you help guys
