Posts: 16 |
if im driving my car with the a/c on it really sucks. its slow as ****, so i dont bother with it but isnt it supposed to shut off at full throtle?? its nice and cold but just SUCKS!!!
~~~~svt racing~~~~ 3.0L
Posts: 176 |
We have a VERY inefficient condesor that is said to zap as much as 20-30 Hp when used. I believe there is a WOT bypass but it doesn't too much cause the condensor deosn't shut down fast enough to respond to someone ripping through the gears. I use the air on the highway otherwise its 2-60 for me!
2000 Roush Cougar MTX MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
Posts: 264 |
I hear your sorrows! I dread turning on the AC because it REALLY puts a burden on the power, especially at this altitude. I've never had a car which had such a big difference with it on and off as my SVT does. Oh well, good thing it's only been in the upper 90's lately. :p
Tim '00 SVT
Posts: 897 |
Yeah, we don't really have that heat problem down here. :rolleyes:
My 99 Civic Si had really weak a/c. It would make it less powerful by far, and it didn't use freon...it used some other tree-hugger crap that took 20 minutes to reach maximum cool temperature.
So it robbed horsepower and took forever to get working...at least the CSVT blows cold
1998 T-Red CSVT (1492 of 6535) Born on 5/30/97 KKM 4.6L TB with custom "Throttle Optimizer" Bassani Exhaust NP-Tuning Sniper Intake Pipe Fog Light Mod with 885's Clear Corners Stereo - Oh Yeah!
GOLIATH - RIP 6/14/02
Posts: 82 |
Check into the fill of the system- I've heard that if your 'freon' is low or high, it makes the compressor work harder (sap more power).
'99 Contour SE Sport V6, 5spd, Dark Blue / Blue
Posts: 307 |
Originally posted by swalve: Check into the fill of the system- I've heard that if your 'freon' is low or high, it makes the compressor work harder (sap more power). That's true for all ac compressors, but the tours ac in particular just zaps the power no matter how much R134a is in the sucker.
'99 Contour SE V6 w/MTX (Black Clearcoat) '02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
Posts: 3,248 |
I sort of had the impression that A/C did not zap too much. Have mine on all summer practically and never really notice it much, still plenty of GO. It does drop gas mileage by 1-2 MPG though..
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 1,202 |
You should notice (on the SVT's at least) that at 6K, with the A/C on, the power comes back. I should stop blowing cold till you come out of your run and don't go above 6K for a second. At least that's what happens on mine. It does suck power down low and take a tic longer to rev it up. Just don't do "crazy" stuff with it on. You have the back up 5-60 A/C.
Married the gal of my dreams 04.27.02  2K SVT Black/Midnight Blue #294 of 2150 DOB 10.29.99 kbucy@fbr.com ktigerj on aim A *few* Mods Best Time 14.942 at 93.98mph Car is now for sale - 14000
Posts: 803 |
Odd to note as well that between both my cars the V6 has a greater powerloss with the AC on as compared to the ztec.
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 1,083 |
1. underdrive pulley 2. windows down :p
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
