Posts: 1,071 |
Pictures of my water pump that went out on Friday.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 416 |
Wow, that's the worst one I've ever seen.
- B
Posts: 282 |
Bummer  . The car I had before the Merc was a Prizm that I added alot of mods like cold air induction custom exhaust and stiff suspention,nice car. But anyway the water pump was leaking so I replaced it then 2 weeks later that one dropped all the bearings, and took the engine with it. ....Brad
Aviation Electronic Tech's RULE!! Your born you die inbetween you work on cars how can we be so lucky. 99'Mystique Zetec VCT ATX "CEG" on front and back windows. 10 inch HED series Cerwin-Vega My ther car is a 1996 4Runner Sunfire red pearl with Bilstein shocks, K&N air filter and Xenon fender flairs "There is always room for more mods"
Posts: 1,151 |
What kind of replacement are you getting? I think you should start a GB on this!
ChickenhawkRacing@hotmail.com 1998: #4415/6535 mods: Sheet metal screws in rear chrome strip Four wobbly corners "Hey, do you like apples?" "Well, yeah." "Well, I got her number, how do you like them apples?"
Posts: 1,071 |
All ready got a replacement. The metal impellar version as well. Check this thread: http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=1&t=011601 $53, not bad.
Posts: 1,151 |
Thanks, I think I may need one someday. I think the previous owner abused this 'tour a little.
Posts: 770 |
Originally posted by Sanctum: Wow, that's the worst one I've ever seen.
- B yeah well to bad i could take any pic and post them of mine....i had about a 2 inch piece left on mine and the rest was just scatter little pieces it sux when that happens though..
2002 Acura RSX Enternal Blue Pearl Blk Leather/5-spd MT. 15.724@87.79 2.397 Sixty Foot(Bone Stock) 134.6HP 130.4TQ (Bone Stock) 139.6HP 130.0TQ (Injen Intake) -------------------------- 2000 Mustang GT Blk w/Gray Leather 5-Spd ET 13.469@102.37 60' 2.004 ----------------------- Former Proud Owner!!! 98 Blk SVT some mods.. 14.955@91.93 #1730/6535
Posts: 1,367 |
was the metal cone still in tact on the backside of the water pump housing? make sure you check that. just putting another pump in will only temporarily solve the problem if that metal cone has come loose. the ford oe pump gives you the whole assembly, including the backside housing with a newly pressed in plate, and a whitish colored impeller. ill be doing mine come spring.
Posts: 1,071 |
Originally posted by SVTour98: was the metal cone still in tact on the backside of the water pump housing? make sure you check that. just putting another pump in will only temporarily solve the problem if that metal cone has come loose. the ford oe pump gives you the whole assembly, including the backside housing with a newly pressed in plate, and a whitish colored impeller. ill be doing mine come spring. It was still intact on mine. When JVT's pump wore out, That was the cause. After a few attempts to get that cone thing to stay put, we just decided to take it out and see if it would overheat. So far so good. Have to wait until summer to see if it still works OK without it.
Posts: 5,805 |
Without the 'cone' you no longer have a pump but just a paddle!,this will not circulate the coolant correctly.I suggest you get the rear housing so the pump is complete.The clearence between the impeller and the cone is a critical factor in any centrifical pump,the size of the hole in the cone affect the suction and flow rate...I suggest you study how a centrifical pump works!
