Posts: 154 |
I was thinking of swapping out my 95 subframe for a 99. I need to replace my steering rack, and control arms, and since I will have the frame out for the tranny rebuild, I thought it might be possible. Does anyone know if the subframes interchange? I would love to keep the newer style control arms...
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
Posts: 5,296 |
I think WorldTour swapped his late style subframe for the earlier style ones because it's "better". Not sure why would you want to go to the late one anyway. But if you do, I believe they are interchangable. The shop that rebuilt my tranny dropped the subframe to drop the tranny, so I think you should be able to swap.
Posts: 1,355 |
Yeah they swap out. Only diff is in the A arm # of bolts. Instead of like 4, there's 2 on each arm. There's even one on ebay. Here. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1832918395
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 154 |
Yep, seeing that on ebay got me to thinking about it. I don't know about the earlier subframes being "better". I would think that in the area of the subframe, engineering would continue to improve... Like the redesigned control arms. Plus, think of all the kewl things you could do to the "new" frame (like Kewl paint schemes) as you take your time putting pieces on it.
Posts: 5,805 |
Early subframes are horiz a arm bushes, late are vert...but watch out ...TWO subframes Auto AND Man...World Tour never dropped his subframe/changed as far as I know????
Posts: 5,296 |
Originally posted by Terry Haines: Early subframes are horiz a arm bushes, late are vert...but watch out ...TWO subframes Auto AND Man...World Tour never dropped his subframe/changed as far as I know???? I thought he did... He mentioned something about swapping out the newer subframe for mthe older ones quite a long while back.
Administrator
Administrator
Posts: 4,527 |
Originally posted by AirKnight: Originally posted by Terry Haines: [b]Early subframes are horiz a arm bushes, late are vert...but watch out ...TWO subframes Auto AND Man...World Tour never dropped his subframe/changed as far as I know???? I thought he did... He mentioned something about swapping out the newer subframe for mthe older ones quite a long while back.[/b]no, Worldtour's car inexplicably has the earlier, horizontal style bushings. He never changed the subframe or anyhitng like that. It is unknown why his has the early subframe/bushings, especially since there is no evidence of an accident, or other major tear up of the car (at least not that I'm aware of)
It's all about balance.
bcphillips@peoplepc.com
