Originally posted by G r y m e s:
What does taking the door dings off intail?
Sore fingernails!
Actually it was much easier than I had thought....I would definatly say the sooner you can do it the better. My car was a 98 and I did them last summer and it left just a few lines. (Not sure why though) Don't get me wrong though nothing you can see without examining it.
Just take some flaws or fishing line and get the corner started....after which just pull it with your hand. I would have a bucket of soapy water handy and if you do it in the sun it helps heat the adheasive.
The key I found was NOT to peal the adheasive off in the direction I was moving but rather PULL it towards the opposite direction. You'll see once you start to do it.
Its a bit time consuming but the final product is definatly worth it. (As you can see
Hope that helps!
