#41981 05/23/02 08:16 PM
W
WOLF24 Offline OP
W
What O2 sensor do I tap into? Also does anyone have any advise on what to tap the positive wire into?
1995 Contour SE
Fully loaded/Leather
2.5L V6
#41982 05/23/02 08:55 PM
Front bank 02 sensor. You will want to tap into the ignition wire for the posotive, and use any bolt for a ground.
98 Black Mystique; Duratec/ATX
"Mystique, the luxury SVT"
P.S. This is what part of the alphabet would look like if the letters Q and R were omitted...
#41983 05/23/02 09:16 PM
W
WOLF24 Offline OP
W
What do you mean by front bank?
1995 Contour SE
2.5L V6
#41984 05/24/02 12:03 PM
Look at the install instructions for the APEX'i that I wrote in the Mods --> HOW-TO Section of www.contour.org. Then use the same wire as used in the "BLUE WIRE MOD" for the APEX'i.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#41985 05/25/02 07:32 PM
I it is the same as mine it is the front o2 sensor of the header and it is the sending wire their are four wires on mine and it was the red and white strpe one you should find out the exact one for your car
98.5 SVT CONTOUR silver 17 inch white rim's and touring wing lowered and custom interior paint
intake and gage pods
