Posts: 1,355 |
Ok, So I'm am looking to get some gauges for my Tour but I have some questions as I know NOTHING about them. 1. Whats the diff between Mechanical and electric? Which do I need? 2. I know I want an Oil Temp gauge, but what others are the most "informative" gauges. I don't just want them cos they look cool. I want them for a reason! 3. I have a pre 98, spmotorsports sells the gauge pod, but it says it's for 98+ only....why? or is this not true. 4. How hard are they to install?
Like I said, I know NOTHING about gauges so if some of my questions are stupid, I apologize now for them. Thanks guys.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 9 |
try to get an air/fuel ratio gauge they not only look cool but they help w/ engine tuning.
Posts: 3,950 |
Well the 98+ gauge pod will fit all Contours. If you can you want electrical, but of course it depends on the gauge. Air/fuel and voltage are good ones to start off on. Install is about medium difficulty. For someone that knows nothing about cars, they will probably be a b*tch to put in.
Posts: 5,805 |
*For oil pressure use a mech gage and hook it up to the main oil gallery or the remote filter if you have one,using the cylinder head oilway is not reading the most important part of the lube system*Oil temp is good as the 2.5 runs very hot re oil temp*A/F is very inaccurate unless you use a stand alone upgraded 02 sensor which will set you back around $300..!!*Water temp,in degrees, is better than L...N.O.R.M.A.L...H *Manifold vac is a useful tuning aid & general engine condition gage......
Posts: 7,329 |
Oil pressure, Oil temp, & A/F or Water temp or Voltage or EGT
