Posts: 128 |
Does anyone know if 98 SVT gauge cluster will fit in my 98 SE, and what mods will I have to do? I did search but didn't find anything. Thanks for all the help? Sergey. :p
98 GREEN SE RACTIVE. 75 NOS. KONIG WHEELS. ST200 UPPER INTAKE MANIFOLD. SVT TB. BOCH +4 PLUGS. 9MM PLUG WIRES. AUDIOBAHN, ALPINE, PLS2 INSIDE. AUTO METER. SVT BODY KIT. SVT GAUGE CLUSTER WITH INDIGLOW GAUGES. MORE COMING SOON.
Posts: 9,178 |
Do you have the Duratec engine or the Zetec? It will fit in both but the tach won't work in the Zetec with out some modification.
Posts: 3,950 |
Originally posted by Pollo_loco69: Do you have the Duratec engine or the Zetec? It will fit in both but the tach won't work in the Zetec with out some modification. Hell yes I know first hand. Tach still don't work right.
Posts: 52 |
my tach doesn't work either...someone figure out how to make it work
Posts: 128 |
I got a duratech, but my sped. goes to 130mph,and SVT's goes to 160mph, how do I go about that? Thanks for all your help.
Posts: 1,692 |
Originally posted by Pollo_loco69: Do you have the Duratec engine or the Zetec? It will fit in both but the tach won't work in the Zetec with out some modification. UMMM wrong.... ON a 2000 it will need some modifications if it is a Zetec... but he has a 98 so all should work fine.
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 9,178 |
On a 99 it requires modification too.
Posts: 3,950 |
Originally posted by ZetecRacing: Originally posted by Pollo_loco69: [b]Do you have the Duratec engine or the Zetec? It will fit in both but the tach won't work in the Zetec with out some modification. UMMM wrong.... ON a 2000 it will need some modifications if it is a Zetec... but he has a 98 so all should work fine.[/b]Damn straight!
Posts: 128 |
Thanks for all your help>
