Posts: 45 |
Anyone have hard numbers on the weight of a stock, non-SVT,duratech, stick car. Thanks
Posts: 494 |
Originally posted by Ianthin: Anyone have hard numbers on the weight of a stock, non-SVT,duratech, stick car. Thanks Look on the inside of your door jam or inside your manual for the weight of your car. Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Administrator
Administrator
Posts: 4,527 |
nope, the door sticker will show GVWR or Gross vehicle weight rating which is the maximum weight your vehicle is designed to handle, the actual weight of the car is considerably less.
(of course, base curb weight might be on the sticker too, but I don't think it is)
It's all about balance.
bcphillips@peoplepc.com
Posts: 7,329 |
Originally posted by Stephen: Originally posted by Ianthin: [b]Anyone have hard numbers on the weight of a stock, non-SVT,duratech, stick car. Thanks Look on the inside of your door jam or inside your manual for the weight of your car.
Stephen[/b]Neither of which will give you the correct number either. One gives estimated weight fully loaded. One gives maximum gross weight allowed. Just go to the local truck scales and get it weighed. Some salvage places will do it for you as well. Make sure to have a full tank of gas so you can accurately know your true weight. (impossible to guess a partially full tank)
Posts: 494 |
Originally posted by DemonSVT: Originally posted by Stephen: [b] Originally posted by Ianthin: [b]Anyone have hard numbers on the weight of a stock, non-SVT,duratech, stick car. Thanks Look on the inside of your door jam or inside your manual for the weight of your car. Stephen[/b] Neither of which will give you the correct number either.
Make sure to have a full tank of gas so you can accurately know your true weight. (impossible to guess a partially full tank)[/b]Doh! You are right, I forgot that I weighed my Pontiac at the scrap dealer. Stephen
Posts: 401 |
lol i'd hope my car isnt 4000 lbs! haha.. no, mine weighed at 2987 lbs  fat car.
*fixed* 1998.5 Contour SE Zetec No Cat, SVT Dual Exhaust, 2 N1 Mufflers, IAT , Diablo Chip, Iceman Intake, Polished TB, "new tranny"
Various other crap, no more mods for a while, just moved.
17.391 @ 81.03 mph
1995 Honda Civic CX Hatchback
15.34 @ 91.67mph
stuff.
Posts: 303 |
I went to the scales one day with a stock SVT and my golf bag (20 lbs?) in the trunk. With half a tank of gas, the car (without me) weighed 1400kg +/- 10kg, or 3080 lbs +/- 22 lbs.
I did a weight distribution check too, and I think it was 62% front, 38% rear.
Interesting tidbit, if nothing else.
Kerry
99 SVT Contour Silver Frost, #365/2760 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
Posts: 2,112 |
Mine was 2975 lbs with about a quarter tank, and without any other baggage (subs, bags, etc).
Posts: 83 |
Non SVT MTX This is without a driver and only a few gallons of fuel in the tank.
Total: 2900 lbs
Front Axle: 1880 lbs
Rear Axle: 1020 lbs
1998 Black LX Sport # 140609 A-6 Sidemarker Lights Front Speakers: JL Audio XR570-CX
Posts: 219 |
- Zack
1995 Contour LX 2.5L V6 MTX 150,000 miles and still going strong PIAA 510's (Finally I can see again!)
"It isn't pollution that's harming the environment. It's the impurities in our air and water that are doing it." George W. Bush
