SCOTTK!!!!
Will the front links cause the rear clunking
Mine are loose and I have this problem. The back is tight!!!
My noise is distinct and comming from rear. How could the noise travel that well from the front links to back??? It would be nice if this was the problem!!!
Oh ya!!! 98 zetec 140 000kms
1) Brake lights leaking water into trunk!
2) front bearings (grrrrr)
3) front bearings (grrrrr)
4) Trunk leak
5) Tie rod
6) Alignment
7) Balancing
8) Balacing
9) Blower motor
10) water pump
11) Resistor for blower motor
12) Wire harness for blower motor.
13) Fuel flapper doen twice (first time severe leaking when tank was full after first recall!
14) Serpentine replaced afdter water pump was done because the FORD dealer forgot to put all 3 bolts in pulley the serpentine runs on and it was wobbling with one bolt in!
15) Recall on water pump redone to cover pulley/serpentine belt problem.
16) Spark plugs were done at 60 000kms! Don't trust the 100 000kms that plats are good for.
17) Spark plug wires replaced and car ran better.
18) Fuel filter replaced twice (canadian gas
19) Rotors / pads (normal for this mileage)
20) Air bag sensor
21) Brake valve recall done on rear brakes!
22) Car still fish tails like a SOB!!! My front links are loose, would this fix the problem? Car is scary in the winter. I wish the the tire spikes were legal in Ontario Can!!!!
23) Road light fill with water and I have to wait at least a day after I wash the car before I can safely turn them on without blowing the bulbs!
I love the car but I hate the
employees at Ford when they say I have never seen this problem before. These problems above are common with these cars and a FORD tech has the nerve to tell me he has never seen this before!! :rolleyes:
FIRST DAY ON THE JOB BUDDY?????
