That looks like a BS statement from your everyday 14yr old troll...I may be wrong...and in that case, I feel bad for this person's car.
But you can drive for a few minutes without a MAF and then the car will stall completely. As I did one day when I was installing stuff, and forgot to plug my MAF back in, and the car drove nicely, and then it all of a sudden quietly stalled. Then started again...drove and stalled again...
Oh well...
I heard that if you take the air filter ocmpletely off you'll have no intake air restriction...try that too
(DO NOT TRY ANYTHING I STATED ABOVE...IF YOU DO, IT"S NOT MY FAULT)
1995 Probe GT ATX TOO MANY MODS 1999 Cougar V6 MTX Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed) Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress) Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress) Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues) Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires  ...
