Posts: 94 |
Is gutting the pre-cats worth it? I want to do this but it sound like a lot of work, Is it? Is the Mil Eliminators need? Are they hard to make? Ok I need to face it IM LOST. Help?..........
Black '98 Contour SVT #162 of 6535 -Indiglo Gauge cluster- -Kenwood KDC-X815- -Audiobahn ALUM12x sub- -Audibahn 18001d Digital Amp- -Audiobahn 1.0 farad cap- -LED side markers/washer nozzels- -KKM Intake - Bosch Plat. +4- -Custom Exhaust - NO res.- -Sho Shop off road Y-pipe- -Fog light fix - THX-Fix- -Koni strurts - Roush springs-
Posts: 7,329 |
Yes Yes its a lot of work. Must be welded too. Yes you need the MIL Eliminators - Easy to make
Posts: 94 |
can some one tell me how long it took them to do there cat project? does our cars have only one o2 sensor after the two pre-cats
Posts: 654 |
Took me about 4 hours to do mine. There are 2 O2 sensors after the cats, one after each cat that is. If you can stand the whole lot of rasp that you will have with no cats. Your gains will be most felt if you have other intake and exhaust mods, such as an aftermarket exhaust. Try searching for more info, there was a fairly in depth set of threads not too long ago that I started (dont have time to search for you right now) but yeah, try searching for alot of info recently... -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 94 |
How raspy are you talking, rightknow i have a rasp for a couple of mins. then its gonewill the rasp go away? When its up to temp and all?
Posts: 654 |
Not really, the reason that your rasp went away when it got up to temp is that the cats are burning the gas and not letting the exhaust bounce all over the place. To get rid of the rasp I am going to be looking into getting a high flow resonator... -Nick
Posts: 3,584 |
Do yourself a favor and take out the O2 sensors when you do this and make sure you have the MIL eliminators too. I got them from Dallas Mustang and they cost $70.00 or you can take your chances and have someone make them for you, yeah that always works :rolleyes: Its well worth it, especially when doing the true duals because my car revs really fast now
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 654 |
Make your own MIL eliminators for $6 like I did... http://www.zx2racing.com/mods/mods_mil.htm -Nick
Posts: 94 |
Thanks guys, I am having the MILs built, and I can't wait for this to happen, the project has been put off due to some rain. (My SVT don't leave the garage when it rains  )But it will come soon, also let me know what you find out about the Res. because I will be intrested in one. Thanks Mat
Posts: 316 |
The Dynomax 17230 Ultraflo resonator is sitting on the living room floor. After the mystery mod and ypipe it rasps, this will take care of it.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
