Posts: 70 |
looks nice, if that is the spray paint type of coating youll want to cure the header in an oven before installing on car. i painted the headers on my mustang w/o curing and 5 min after fire up all the paint started flaking off and yes i prepped the metal before painting. any way put in oven for i hour at 500 F.
96 COUNTOUR SE
Posts: 852 |
The higher temps are likely what causes the warranty void on the MSDS headers. Even if they are coated with ceramic, a little crack would oxydate thebase metal much faster at higher temps.
------------------ Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 3,598 |
Come on guys, MSDS says header wrap will void the warrenty for two reasons:
1) Already jet-hot ceramic coated 2) Header wrap traps in moisture and causes rust (these are mild steel, if the ceramic coating wears off they'll rust pretty damn easily)
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 2,166 |
I picked up a can of the spray from crutchfield, its starting to flake off now but it looked good in the begining. All I had to do is spray paint it on... Originally posted by BLUEOVAL: looks nice, if that is the spray paint type of coating youll want to cure the header in an oven before installing on car. i painted the headers on my mustang w/o curing and 5 min after fire up all the paint started flaking off and yes i prepped the metal before painting. any way put in oven for i hour at 500 F.
Posts: 2,166 |
Originally posted by david z: I picked up a can of coating from JC whitney (stupid me), its starting to flake off now but it looked good in the begining. All I had to do is spray paint it on...
Posts: 744 |
your an idiot you piece of donkey dung!!!
Black 99 SVT Ground Control Coilovers 19" KMC Tensions (Gunmetal)
Silver 98 SVT Ground Control Coilovers 19" KMC Suicides (Flat Black)
Posts: 123 |
DavidZ...
Headers look great. So does the Nortel i500 plus twin pack deal for $49.. LOL...
------------------ Whitey 99 Blk/Tan SVT SCA CAI w/ Monster Flow
Posts: 2,166 |
Hey check it outt, $19.99 for a razor knock-off
