Originally posted by mcon99:
you don't need a kit to do this... for a battery tray/box, try the local marina/boat dealers. They sell them.
Get some thick (4 gauge or better) wire with a couple of fuses from your local car audio shop and your all set...
close, but not quite!
marine box is great. it's what i used on my vw. some track racing ckts complained. so i put holddown brakets through the bottom of the marine box.
as for wire, don't get that audio stuff. it's nice, but waaaay overpriced. go to a welding supply store and get some 4 ga copper stranded welding cable. you can get the terminals from them or the car parts place.
i think mine was $20 for the box and about $6 for the cable. maybe $2 for the terminals.
when you ground in the trunk sand the paint off where you intend to ground, bolt that terminal on, and then paint over it.
good luck!
