I have a 96 SE 24V and Im looking to put dual exhaust on it the muffler guys here in Sioux Falls South Dakota are mytified and want to know if they can cut right behind the Cat and remove the resonator and run 2 1/2 inch pipe back and Y it after the gas tank to 2 Thrush Turbo Mufflers what do you guys think???? I want this done right and with a quality throaty sound similar to if not like a SVT also I would need a rear SVT bumper and need one new or used cheap where can I find one ??? also is the spacing between the duals on an SVT the same as a single on a SE like If I put duals on now would the Bumper fit around the duals later??????? Thanks, you guys are awesome!!!
96 Black SE 24V, F/R Disc, K&N Fuel,Oil,and Air Filters, Ford 9mm Wires, Bosch PL+4 Plugs, Xenon Gas Super Whites for headlamp and foglights, 800 Watt MTX Audio System. Many more upgrads coming summer '02 as money comes in.
Gotta work hard ya know, to have the toys to go!
