Posts: 1,444 |
ok i know u can put in a lit moonroof switch. can the same be done for my rear door window switches? would the install be the same as moonroof?
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 1,251 |
At the bottom of the drivers door window control is a sliding switch. Push it to the green setting (looks like two windows) and the rear switches will light up. They turn off when the window lock is turned on.
Posts: 1,444 |
ghosst, thanks for the answer. i cant believe i never noticed that. i feel dumb. thanks again.
AIM:omegazodiac
Administrator
Administrator
Posts: 5,037 |
Don't laugh at him! WHAAAHAHAHAHAHAH!!!!  :p
Posts: 174 |
That kill switch shuts the window lights off on my 98 SE but not on my 97 Sport. Is there something wrong with the switch if it doesn't shut the lights off when it is engaged? Thanks.
1997 Contour GL Sport ATX Zetec/2.0 liter
K&N High Flow Air Filter Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-204) Fram Sure Drain System Ford Motorsport 9mm Racing Wires Recontented Fog Lights, Rear Dome Light, Underhood Courtesy Light, Glove Compartment Light Pirelli HPs Kenwood in-dash CD player Infinity 5752cf speakers World Champion New England Patriots Fan for Life!
Wife's Car: 1998 Contour SE ATX Duratec/2.5 liter
Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-210)
Posts: 31 |
hmouta dont feel bad I also Just found out somthing new i was wondering the same thing
(goe's out to car flicks switch back and forth thats amazing
Posts: 3,934 |
Originally posted by J. Salvi: That kill switch shuts the window lights off on my 98 SE but not on my 97 Sport. Is there something wrong with the switch if it doesn't shut the lights off when it is engaged? Thanks. The lights in my `96 are on all the time too. My switch is stuck with the rear windows turned off. Glad I rarely have rear passengers.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 1,367 |
Originally posted by hmouta: ok i know u can put in a lit moonroof switch. can the same be done for my rear door window switches? would the install be the same as moonroof? dont feel bad. it took me 6 months to realize my driver's seat had power lumbar! :rolleyes: btw, did u get that clock working yet?
Posts: 95 |
you know i have had a mystique for 4 years then traded and got my svt and had that 2 years and about a month ago i just noticed that when the rear window lock-out is on it cuts power and the window lights (maybe handle lights too mine are wired into the window switches so they shut off too)
kinda cool
"It's the little things that count" The Wedding Singer
svt24v@yahoo.com ICQ: 3699352 (Contour.org for auth) 00 SVT #555 of 2150 Built 11/24/99 Bought 12/23/99 T-Red/Tan KKM No Resonator Amber Cougar Side Markers Cougar/Focus Antenna Heated Drivers Seat Heated Mirrors
Posts: 443 |
Does anybody know how to completely get rid of that stupid xpress window opening feature? Man I hate that.
