Posts: 99 |
Finally got the pics of the ram air scoop we put in my 'tour. It's all hand-formed sheet metal and has a massive water drain too. I'm really proud of the workmanship-- hope you all don't mind a little showin' off. http://www.geocities.com/callmecam2/scoop.jpg http://www.geocities.com/callmecam2/scoopcu.jpg
callmecam2@hotmail.com "You might be a king, or a little street sweeper ... but sooner or later, you dance with the Reaper! Yeah, get down with my bad self."
Posts: 99 |
YIKES! Sorry for the pic size! First time addin' 'em . . .
Posts: 1,149 |
Umm... once again... would be nice if we could see em'....lol Dom
Posts: 277 |
CAM2, Would you be willing to get me a copy of your B&M instructions? I juts bought a used one and they might help me out some.
I love the grills and the intake hole! How did you do the grills, what material?
Thanks, Matt oneqwicktwo@hotmail.com Fax: (330) 499-5933
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound Administrator www.fordcontour.org
Posts: 99 |
The grilles I made . . . they come in flat rectangular sheets and you just cut 'em to fit. It's $30 a sheet (and probably costs $.04 to make). Comes in polished (mine) and anodized red and blue. I can hook you up with the place where I got it if ya like.
No problem on the instructions. Still have 'em and would be glad to make a copy. I might even be able to scan 'em at work if ya like. Just drop me a line.
~ Joe
Posts: 277 |
Yea, if you could send em' I'd appreciate it. My contact is earlier in the post. By the way, does one sheet do all the grills? Do you have the factory grills behind or not?
Posts: 99 |
It took 2 sheets to do the whole car. The kicker is I needed the second one only for the main grill (with the blue oval)-- one just barely didn't cut it. The ground effects grills, front and rear, are still there-- I just sandwiched the stuff in and used the stock clips. The ram air scoop grill is sandwiched between the fenderwell and the teardrop connector the KKM mounts to. The main grill I had to cut completely out . . . but there is a nice platform behind to mount the grill onto. Just cut it to shape and hit it with sheetmetal screws. I'll get those instructions tonight and try to scan/send 'em tomorrow.
Posts: 1,447 |
I am dying to see a tour with scoops, I cant see the pics you posted, please retry, I need air.......lol
Posts: 703 |
Hey, lets see some shots from inside the hood!
Looks great, again, nice job!
Seeya mike
Seeya FUseface "Superhero Extrordinaire" "I am Nigh-Invulnerable!" 97 LX Sport
AIM:MiguelAD8
Posts: 99 |
I have pics over in the General Mods section-- Chris Hightower worked some kind of magic and made 'em viewable. Sorry-- this was my first attempt.
As for under the hood, it just looks like a KKM setup. Filter-neoprene hose-SVT airbox piece that bolts to inner fender.
I have a pic, but seriously, it'll look no different than any other 'tour with a KKM.
