Posts: 76 |
Cardoc, anyone? Need someone to fill me in on how to do this mod. Please
A.J. (Scratch) 2000 SVT Black/Prairie Tan (Guinness Edition) 147/2150 KKM Tru-Rev Motorsport 9mm Wire Set PIAA Super Whites Amber Fog Lights Razo Carbon Fiber Pedals Richbrook Shifter/Em. brk AOL Im:AFrint7065 phrint@hotmail.com
Posts: 277 |
It's a 5 volt resistor placed in the power line of the air temperature sensor that is located just before the throttle body in the intake. It adjusts the fuel flow accordingly to give the correct amount of fuel to the engine when it is running at high rpms. This is accomplished by "fooling" the computer by making it believe the air temperature is 20 degrees cooler than it actually is. You see Ford, being as conservative about the environment as they always are have starved our engines of the fuel that they need when they need it most, therefore cutting into our fun. This mod causes a huge gain in power over 4000 rpm and costs only $.20. Thanks to Dom for the idea and the part to do it by the way. :p
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound Administrator www.fordcontour.org
Posts: 1,149 |
Hehe... actually it's a 5.6Kohm resistor placed in the 5volt signal return line to the computer... But yes.. It does do some amazing things on the top end. Dom
Posts: 22 |
Originally posted by Cardoc: Hehe... actually it's a 5.6Kohm resistor placed in the 5volt signal return line to the computer... But yes.. It does do some amazing things on the top end.
Dom  There are advantages and dissadvantages about this mod. Correct?
Posts: 413 |
So where is the how to? Or is this a secret Cardoc mod..  Also, I need clarification.. You are telling me that Ford runs our engines on the LEAN side at high RPMs? That is scary. After this mod, is power lost anywhere else in the RPM band? Later, Patrick
mailto:paw@ite.com Still plays with cars 1999 SVT #2003/2760 Born on 04/22/99
Posts: 703 |
I finally got off my lazy butt and did this. I didnt notice any difference in the lower rpm's, And, since I am pretty much grandpa, I dont take it too high in the rpm's either....but the few times I did, it pulled pretty good.
Thanks Dom
BTW, working on putting the new exhaust pipes Got all my Hardware, and just need to find the time to put it in.
Seeya Mike
Seeya FUseface "Superhero Extrordinaire" "I am Nigh-Invulnerable!" 97 LX Sport
AIM:MiguelAD8
Posts: 1,149 |
Ok... I'll be perfectly frank when I say that it doesn't have the same effect on the non-SVT engines as it does on mine. This was a study and it has yielded some interesting results.. More based on the fact of the way the SVT fuel mixture is controlled and also the mean enrichment on full acceleration.. I have a ton of ideas right now and I'm in the process of procuring parts for a little minor intake overhaul shortly.. Including injectors.. So stay tuned.. You never know what you'll read about next.. And BTW.. I did get the ok to bring the Viper to the meet.. But do I really want to is the question..lol Hmm 1997 with 9,000 miles on it.. HEHEHEHEHEHE!!!!! Dom
Posts: 703 |
Originally posted by Cardoc: Ok... I'll be perfectly frank  OK uh...Frank  I just figured it was because I need it for work, and I dont beat the crap outta it...maybe I will test it tomorrow  I can hear the wheels spinning over here in Buffalo...I would imagine we have some cool surprises at the next meet to check out... WE'll have to get you an evil scientists hat and glasses. Pretty soon there is going to be a new web site.... www.cardoctorstinkersite.com Hey, ya never know. CYA Mike
AIM:MiguelAD8
Posts: 1,149 |
Hey Mike, Could you find me that evil scientist hat and those glasses?? They may come in handy real soon...lol Dom
Posts: 428 |
hay dom, u have a how too on that yet?
Its a bird, its a plane...wait!..W.T.F.W.T..? #1800 of 2150
