Posts: 68 |
I get my oil changed at the dealership. I've read that the dipsticks are slightly off and would like to add more oil. Question is, what kind of oil (brand) should I be adding? I see on the dealer receipt that they use 5w30, but doesn't say what brand or anything. Does it matter? Thanks!
Posts: 654 |
Assuming you have a 6cyl. You should be running at 6 quarts of oil, to prevent the disaterous oil starvation problem that we are so prone to. As to brand, that can vary from person to person, I dont know anything about oil brands, so I wouldnt try and tell you which brand to use. -Nick
"My family hauler can kick your family hauler's @SS!" ~~~~1999 Contour SE Sport~~~~ -KKM True Rev -Custom cat back Flowmaster exhaust -All Cat's fixed. -SHO Shop Off-Road Y-pipe -Many other Mod's done...
Posts: 316 |
I run 6.5 qts of oil. 99k and no problems.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 1,861 |
Most Ford dealers use Ford's own brand, Motorcraft. You should ask them to make sure. They should be able to tell you.
Jim Johnson 98 SVT
Posts: 463 |
6 quarts of Quaker State 5W30, plus K&N oil filter every 3,000 miles.
Posts: 5,296 |
6qt Mobil 1 5w-30, every 3-5k miles depends on driving style.
Posts: 68 |
Originally posted by Big Jim: Most Ford dealers use Ford's own brand, Motorcraft. You should ask them to make sure. They should be able to tell you. Would it hurt to add a little Penzoil or Quaker State to get to the appropriate level? Or do I have to add whatever brand Ford uses? Thanks for the response guys!
Posts: 1,444 |
see sig for oil. i dont think it would hurt to add a little oil from another brand as long as its the same weight and type (dont add synthetic to motorcraft dyno oil). does this sound right to anyone else?
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 1,701 |
5W30 is 5W30. You can add any two same weight oils together and they are chemically similar enough to be basically the same as far as the engine is concerned. You can put synthetic in too. As a matter of fact they even sell it already mixed up and call it synthetic "blend". Maybe a little better properties than pure dyno, but who knows??? Doesn't say how much is synth and how much is dyno, so probably not worth the extra $s.
