#338942 07/29/02 06:02 PM
Wow is all I have to say, for about 100 cdn I have a watercooling system!! This is great, although a little ghetto. The system wont go past 35C no matter what I do. bubba beer tank holds water and pump, old heatsink drilled out and sealed, crummy 6 inch radiator and old 92mm fan and a POS RIO pump. This is a pretty simple thing to do if anyone is interested I can help. OC'd an old celeron to 1170mhz from 900 havent tried going any higher.
Currently: 2002 ztw focus wagon, black, manual. Yippee it sucks!!
blitzkrieg53@hotmail.com
#338943 07/29/02 06:07 PM
how's the noise? I'd buy watercooling if I could eliminate most of my fans.
-Louis
1998 Black E0 #3826, lightly modded
#338944 07/30/02 04:15 AM
N
N
i did the same with mine, i suggest u do buy a waterblock, and not make your own. but if your going water cooling get a shim for your processor if its a amd athlon. i burnt 1 out because of wear and tear of trying 2 profect the heat sink.
Experience is the worst teacher; it gives the test before presenting the lesson.
"You peel my onion down to the nun" - Gene Hackman [Under Suspicion]
-Walter-
96 Contour LX
#338945 07/30/02 04:52 AM
the pump I have is cheap so the noise is about as intrusive as the dragon orb I had on there before but if one splurged and bought a better pump Im sure the noise would be almost unnoticable. waterblocks are too much work spend some cash on a waterblock they perform better and are guaranteed to fit. The koolance 100 and 200 seem to be pretty good buys.
tubing 5
radiator 30
pump 30
tank 20
this is what I had to shell out, everything else I had lying around, 3/8th adapters, zip ties, fan, plumber goop(this makes it possible)and an old fin cooler for waterblock, took me about a week to build in my spare time.
