#40884 04/10/02 06:00 PM
mangler Offline OP
First, I'd like an idea of the cost for this part, and maybe even the necessary brackets. I`d really like to retrofit it to my car...
Anyone have one in hand? I'm wondering what the hole size and hole to hole
dimensions are?
Is this as harsh as a gas shock absorber? Softer? What is the approximate cartridge dimension?
The engine roll is getting pretty old on my car, and I would like to avoid filling the rear mount with urethane, to prevent undue vibrations.
TIA
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
#40885 04/10/02 06:21 PM
H
H
On the Performance Fords website, it looks like we SE owners might be in luck for a torque brace to place on the engine to help vibration.
Try calling them for a price and ETA.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
#40886 04/10/02 10:36 PM
Marco, you can have mine if you want.. leaking oil and all.. :rolleyes:
I need a replacement and I think it was a LOT more expensive than Performance Ford's kit last time I checked... When I have some extra $$ I'm getting the Perf. unit..
#40887 04/10/02 11:53 PM
I had the SMA torque Brace. Solid piece of metal that replaced the Stab-o-Shoc. I didn't really see any benefit to it, other than inducing more NVH in the pedals. Oh yeah, with 1.5yrs on it, its about to break. the OE part has been reinstalled and the annoying harshness is gone. smile I say go Stab-O-Shoc, plus, the rigidity puts an extra load on the rest of the roll restrictors.
Chris
NJ
98.5 SVT Silver Frost w/Frankentrans
carsla AT optonline DOT net
#40888 04/11/02 01:44 PM
mangler Offline OP
Yes, I am a bit weary of trying a solid mount solution...
Anyone ever hold the stock stab-o-shock in their hands? I`d like to have an idea of the length and damping this thing has...Who says you can`t replace it with an el cheapo gabriel strut from a small car? Pending the length issue, of course... wink
Marco Tatta
#40889 04/11/02 02:10 PM
Marco,
Swing by on Saturday, my car's gonna be on the lift at the place up in Laval. You can take a good look at it then, even take it off if you want to measure it...
..I need first dibs if you come out with an alternative! smile
#40890 04/11/02 03:08 PM
mangler Offline OP
Cool. I can take a look at those brackets while I am at it... smile
Marco Tatta
#40891 04/12/02 11:51 PM
I'll take a pic of the SMA piece, uninstalled of course, this weekend.
Chris
NJ
