Posts: 926 |
What makes Ferrari's destinct tone? Just the exhuast system or the way the engine is built?
Yes I know this is a stupid quetion but I want to know for sure.
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 4,476 |
it's a mix of high-dollar valvework and the exhaust - probably due to the fact that the engine is only inches away from the exhaust tips too like my neighbor's F355 - what a sound!
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 926 |
All I ever see is your next door neighbor with the dragster. It seems he's always rebuilding that engine.
Posts: 2,260 |
Bore/stroke ratio, cam gearing, valve size, header shape and size, and well the fact that it's a ferrari. No you cannot get any other car to sound like it James
SVT with CE light mod and a camera mount. Naughty Pictures Why yes it is true, I am on my third engine.
Posts: 72 |
Ferrari V-8s use a "flat" crank instead of the typical 90 degree crank. It makes the exhaust plumbing easier to do, and Ferrari says it's worth about 5-10% on the horsepower. Incidentally, Maserati, which is now pretty much a deivsion of Ferrari uses conventional 90 degree cranks.
A flat crank makes the engine into essentially into two four cylnder engines joined at the crank, 90 degrees out of phase. If you have ever heard a Cosworth F-1 engine from the 70's, they sounded much the same. (And all current CART engines, but it isn't quite as evident because the turbo blends the exhaustt sounds some.) The reason most everyone else uses the 90 degree crank has to do with smoothness. A V-8 with a flat crank will vibrate more than a conventional crank.
The first yeear of the IRL cars, they were required to use 90 degree cranks. They sounded like a bunch of trucks (like a Nascar race, but I digress.. "Nascar: the WWF of racing"...). Then Tony George decided that just wouldn't do and allowed them to switch to flat cranks. Engine note changes to what we hear today.
(BTW, the strangest sounding V-8 I ever heard was the Honda "big bang" CART engine. They had were working with firing multiple cylders at once in the bikes and thought it might work with the CART engine. They never publicly divulged exactly what they firing order was, but it was thought that they were either firing all 8 cylinders in one revolution, or were firing the cylinders in pairs. Anyway, it sounded sort of like a Ducati on steroids. It didn't work because of the turbo. They only used it for a few races in the early 80's.)
Posts: 244 |
Well.. if it's not angled, then it's not REALLY a v8, now is it? Also, there is a DiSTINCT sound difference between the 8s and the 12s. ( and 10s for that matter...  ) --JamesT
>--------------< --Chemguru
99 CSVT Frost /Mid. Blue
00 Suzuki SV650 Red, Naked
Posts: 816 |
Tape a ferrari, then put speakers at back of car and play it. Your car now sounds like ferrari.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 926 |
Originally posted by Redcon96I4: Tape a ferrari, then put speakers at back of car and play it. Your car now sounds like ferrari. I might as well put a Honda badge on the grill then :rolleyes:
