Posts: 520 |
Workers are resurfacing the street outside! I am here for a couple more hours. Does anyone know what kind of dry time there is, or if there is any at all? I am thinking that all kinds of crud is going to end up on my car when I leave. Any ideas how to avoid this?
::edit:: Guess you can call me a topic starter whore.
98.5 Contour SVT totally stock...for now.
-Talk about high performance...I have a K&N Oil Filter....AND a K&N Air Filter!
Posts: 1,831 |
Drive really really slow~
Basically creep like your gonna do a drive by
that way the excess asphalt and tar do not get flung about by the high speed.
Posts: 520 |
that way the excess asphalt and tar do not get flung about by the high speed. I was thinking that. But would there be asphalt and tar that get stuck in the tires and once out of the resurfaced area, it would be flung out after increasing my speed?
Posts: 494 |
Take the bus! *Edit* Spread vaseline on the lower pannels of your car!  :rolleyes: Stephen
96 Contour, GL, Zetec, ATX. 03/18/1996 Build Date. Drop in K&N NGK Laser Platinum Premium Spark plugs Niehoff Premium Ignition wires Wheel Well Air Intake Resonator removed. *Just the beginning*
Posts: 60 |
if we could only develop some sort of morphing teleport system quickly we could save the car! otherwise... drive really slow. even if tar gets in the tires, it wont be as bad as it would be if you drove real fast. and if you want, you could stop right after you got off of the surface, find a stick and do your best to poke the access out. sounds funny, but ive done it a couple times believe it or not.  hope this helps.
im doin a 100 on the highway... so if you do the speed limit get the f*** out of my way.
Posts: 520 |
You guys are great. Maybe after I get off the bad area, I will check the situation. Maybe I should just move my car now to a safe area! But man, those seats sure get hot sitting in the sun.
Posts: 520 |
There is still time. I am gonna make a run for it!
Posts: 724 |
Originally posted by Stephen: Take the bus!
*Edit*
StephenIf I were to put vaseline on my car would = me humping my car. That was the only thing keeping me from doing it in the first place!!! :p
98 V6 Lots-o-mods SOLD 88 Daytona Shelby Z TII (The beast) 87 Daytona Shelby Z TII (Holy 20 psi of boost batman!) Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
Posts: 1,795 |
They repaved a street near me a few weeks ago, even going 15mph I still got tar on my quarter panels.  Finally got it off though, it just took some paint with it
Every time I come online I wonder if the forums will be up
Posts: 587 |
SeR Guy If I were to put vaseline on my car would = me humping my car. That was the only thing keeping me from doing it in the first place!!! LOL.. I have thought that MANY times... I have actually kissed my car goodnight, believe it, or not. NO, I am NOT crazy.. I was just happy... Ray
