Posts: 2,246 |
Anyone know of a good motherboard that can be had fairly cheap. I am looking to upgrade my computer and need a MB for an Athlon XP. I am getting a new board, processor and RAM. I want to spend about $300-$400 for everything. Any tips?
David Litsky AIM: DaveL225 My Car
Posts: 2,848 |
Top of the line are ASUS, ABIT, EPOX, etc. For everythign you will probably go over budget. Look on www.pricewatch.com, the "Bargain" boards aren't bad at all. I've personally used AMPTRON, MSI, and Biostar...never had any problems. Go to www.3dcool.com and make sure you have a nice fan for that cpu of yours. I bought an orb from them 2 years back, it's still kicking and still keeping the cpu icy cold
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 818 |
I can recommend two lower-end motherboards: the Abit KT7-A and the Soltek SL-75KAV/-X. Both use SDRAM memory rather than the newer, faster, DDR RAM, so it's your call on what you want to spend. My son has the Abit in his 1.2 gig Athlon machine; I have the Soltek in my 1.33 gig Athlon machine (on which I'm typing this). We put both together this year. Unless you're into very serious gaming, either should be sufficient, just get plenty of memory (we have 384 megs). I think I paid about $65 for the Soltek, $70 for the Athlon (remember to get a good heatsink fan for any Athlon), $70 for the memory...so you can keep the costs way down if you work at it a little.
2000 Contour SE Sport T-Red MTX, Mystique rear dome light, Blau Florida cd.
Posts: 1,831 |
ECS K7S5A
Have one running a 1.2Duron and no issues. Board can easily overclock your chip and has some nice features.
4Dimm slots 2 for PC133 and 2 for DDR 5PCI Onboard sound and LAN
Should be had for around $50
They sell this board and 1.7+ XP's for $119-$129 at my local Frys when they go on special.
Posts: 1,795 |
EPoX EP-8KHA+ $92.00 Athlon XP 1900 $117 crucial 256mb DDR ram $60x2 Thermaltake volcano 7 $15
$344 plus shipping. You might want to consider getting a new power supply at the same time....trust me
-Pete
Every time I come online I wonder if the forums will be up
Posts: 148 |
K7S5A and K7S6A should both be fine and are very cheap. They are both from ECS. I've used on with a Duron 800 and on with an XP 1600+ and they're both pretty stable. Not as stable as my MSI board but still good for the money.
Posts: 249 |
www.newegg.com Look into the MSI motherboards.
~~~~~~Mike~~~~~~ Silver 2000 Contour SVT # 1200 of 2150
Posts: 212 |
No problem! Top of the line motherboard $140 to $160 AMD XP 1900 $110 Memory PC2100 256MB name brand $50 to $60. Check out Anandtech or sharkyextreme for reviews on motherboards and just about anything else you want to know. And when you decide on a MB go to the manufacturer's web site and check on what brand of memory the recomend. Some motherboard's don't like some brands of memory. i.e Asus and Micron With that kind of budget your in plenty good shape! Also check out the hot deals forum on Anandtech. You can pick some great deals off that sometimes!
Rice is just a matter of money. How fast do you wanna look!
99 Contour Sport SE MTX KKM filter, B&M shifter No res, BAT kit, Aussie Bar
Posts: 2,683 |
They sell this board and 1.7+ XP's for $119-$129 at my local Frys when they go on special. Ditto! have had one for over a year running a 1200 athlon at 1256MHz(fastest I could go and still boot)using a updated bios.Runs great every day!
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Posts: 2,683 |
By the way got mine with processor and Volcano for $155!Then gotr the 512MB DDR for $71 shipped from Crucial.That was back when memory was cheap!
