E
Eli Offline OP
E
my friends dodge caravan is making a metallic sqealing noise from the front driver's side wheel whenever he turns left. its not the brakes, thats another independent squeal. wink anyway, any of you guys got suggestions? what could be making that noise?
96 Contour SE, MTX
2 Pioneer 12"s in a bandpass box
2 5x7 Pioneer Plates
2 Stock Speakers
600 watts of blistering radioshack power
could be a lot of things, can you feel the 'squeel' in the steering wheel when you turn? could be a jacked up wheel hub, poorly attached tie-rod, wheel bearing, or just a brake pad thats worn unevenly... or about 5 other things frown
-Speed Demon- Matt
Black 2000 Contour SE Sport (duratec/atx)
got body mods?
all show, better than stock go smile
"I might be crazy, but I'm not stupid"
speddmn.com
9
9
Dodge Caravan, herein lies your problem...
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
