Posts: 1,040 |
Besides the addition of a Mystique rear dome light has anyone added a courtesy light for the rear seat?
The footwells are particularly dark in the stock car since light from the front dome is blocked by the front seats and there are no door puddle lights.
I am reluctant to butcher headliner to add a dome light in the rear, like my '98 Mystique. I'm thinking something at the rear of the console might be easy to add.
Any suggestions?
Posts: 803 |
I'm thinking of putting lights in the rear pillars ala Lincon Mark IIIV. Figure I can pull those from a bone yard for cheap $.
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 1,040 |
That's an idea, although I'm not familiar with the Lincoln lights you mention. A lot of those luxury cars have map/reading lights in that location. I checked my car quickly in driveway (its been raining most of the day) and see that you would have to stay away from the shoulder belt retractor, also the trim seems to be all curves. I'll pop the trim off in better weather and see how much space there is behind it.
Thanks for the reply.
Posts: 1,444 |
now thats an interesting idea, maybe lights in the c pillars. i agree about being nervous about cutting the headliner.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 2,657 |
Originally posted by hmouta: i agree about being nervous about cutting the headliner. Pansies... I added the rear light along with a number of others and can say its a very easy mod. Just make sure you use a sharp exacto knife so you don't have any jagged edges. The mount/hole already exists in the roof of the car so its hard to go wrong with where it mounts...sort of like a template I guess. I've also added the display for my processor(stereo) to the front of my headliner just above the front light...Email me and I'll send you a pic. As for putting lights in the C pillars that would be a much bigger job than adding the Mystique dome light. And it might not look quite as stock. My $.02 sqplus@my99svt.net
Posts: 2,112 |
I agree, cutting the headliner is really easy. If you use the roof as a guide, it's impossible to mess up. And even if your cuts are a little jagged, the dome light bezel is very wide and covers it up. Probably the most stock-looking solution for rear illumination possible (since it is basically stock on the Mystique)
Posts: 1,040 |
SQPlus & louisw: I just get in my Mystique to see benefits of rear dome light. Did either of you do the mod to a Contour with a moonroof?
SQPlus: Link requires a password to access pics.
Posts: 174 |
I also agree with the rear dome light being an easy mod. The hardest part was running the wiring from the back to the front. I just wish I could get more power (illumination) out of the lamp. Is there another bulb I could replace the stock one with to get more light without melting the plastic?
1997 Contour GL Sport ATX Zetec/2.0 liter
K&N High Flow Air Filter Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-204) Fram Sure Drain System Ford Motorsport 9mm Racing Wires Recontented Fog Lights, Rear Dome Light, Underhood Courtesy Light, Glove Compartment Light Pirelli HPs Kenwood in-dash CD player Infinity 5752cf speakers World Champion New England Patriots Fan for Life!
Wife's Car: 1998 Contour SE ATX Duratec/2.5 liter
Mobil 1 SuperSyn 5W-30 Mobil 1 Oil Filter (M1-210)
Posts: 303 |
SQPlus, is there any way you can make those pics accessible (needs login). I'd love to see the rear dome light mod completed.
Kerry
99 SVT Contour Silver Frost, #365/2760 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
