Page 3 of 3 1 2 3
#39647 03/14/02 08:58 AM
H
H
why not get a wider wheel. instead of the stock 6.5 wide, go with a 7, 7.5, or 8 wide.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#39648 03/15/02 08:57 PM
"Function before fashion."
'96 Contour SE
#39649 03/15/02 09:57 PM
Hehe.. i knew a young someone who did that on an oldsmobile. He and his passengre were quite suprised when the wheel flew off on the highway eek luckily no serious damage or injury.
T-Red SVT E0 #2321 of 6535
#39650 03/15/02 10:55 PM
i had them on my car for a lil bit cuz i needed adapters to make my rims fit my car ....which is basically like a spacer....i didn't like it at all and i totally suggest just buying wider tires...do no get the spacers...they r dangerous...u never know when they will give away and your tire will come flying off....i had rubbing issues and all kinds of headaches....i gave my spacers away that is how much i hated them
#39651 03/16/02 02:55 AM
H
hanknum Offline OP
H
Wider rims and/or wider tires are not the answer. First of all there are limits on how wide a tire you can put on any particular rim. Even if a wider tire can be mounted on a particular rim, the extra "bulge" beyond the rim may create other problems, like too much sidewall flex.
Also, a wider rim may not do anything because it also depends on the offset of the wheel.
I believe spacers can be used, if done right.
Page 3 of 3 1 2 3
