Posts: 61 |
the water pump. It's leaking. It looks like it's leaking from the top side of the pump. I'm wondering if it's that 50,000 mile thing. I just turned over 50k about 2 weeks ago. It started leaking on my way home from Bear Lake on Monday. I kept a real close eye on it Tuesday and Wednesday, only driving to and from work. It was leaving a little puddle trail on Wednesday when I got home from work. So, I had my dad bring his trailer and take my car to his house, Wednesday night. (oh it sucks being without a car) Here's the plan, I'm changing the pump, gasket, belt, bolts, and the 2 hoses the attach to the pump. I'm gonna pick up the stuff at lunch today and change it tonight. I've looked in my repair manual and I'm guessing it'll take about 2-3 hours.
Dave, '99 Cougar, Black, V6, MTX, loaded, and modded oh ya, got some good tunes to Coming soon: Yodude exhaust, Venom or NX (spring '03) Dream: Turbo 3L (anyone need a kidney? hehehe)
Posts: 9,178 |
That sucks.  They seem to go like clockwork though don't they? I hope all goes well tonight.
Posts: 19 |
1996 Contour GL ATX MODS: cta intake essilenger udp odp 9mm ford racing wires hp accel coil custom fog lights SVT TRIM WILL POST PICS SOON 2 sets of 17 in rims custom wood dash magnaflow exhaust
Posts: 61 |
reset the timing The repair manual doesn't say anything about that. Oh wait, it does for the Zetec. I've got the Duratec so I won't have to worry about that.
Posts: 3,934 |
Timing is a non issue for me now.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 61 |
ok, water pump is all changed. It all went pretty well. I just gotta spend some time cleaning the mess it made. click here for pics
Posts: 1,627 |
About how long? How hard was it? I heard its pretty simple compared to most cars. Just wanting some comfirmation.
00 Black SVT #1545 Ground Control. Koni. 18" Konig Tantrum. More.
Posts: 61 |
well after reading the repair manual, I figured about 2-3 hours. I think it took about 3 hours to change out the pump. And about another hour or so to make sure everything was done and get the cooling system full again. It wasn't really hard. But it was just a lot of stuff to do. Ya, compared to most cars, this was a breeze! The hardest part was getting one of the hoses back on. The long hose that goes from the pump and turns down into the top of the block (below the throttle body) was kind of a pain. here's kind of an interesting thing about it. The pump from batinc.net and spmotorsports.com shows just the pump half, NOT the housing (which is what my biggest problem was). The pump that I got from Ford had the pump, gasket, back housing, and the two big hoses all as one part, all put together  and it only cost me $64 bucks! I also had to replace the 3 torque to yeild bolts, so the total cost of parts was $66 dollars even.
