#39068 02/21/02 02:31 PM
Murph Offline OP
I just replaced the radiator on my 98 SE and the new one has two brass inlets that I assume are for an automatic tranny cooler, could I use these as an oil cooler? and does anybody know what size these male connections are?
Murph
Mild mannered school teacher by day
Unapologetic car nut by night
98SE T-red
Bat intake
th fix
poly bushings and motor mount
DMD
Fumoto oil drain valve
#39069 02/21/02 07:01 PM
I wouldn't even attempt to use it as an oil cooler.
The last thing this engine needs is more oil trapped out of the pan... laugh
2000 SVT #674 - Check it out!
#39070 02/21/02 08:10 PM
Murph Offline OP
Thanks, your probably right
Murph
98SE T-red
Bat intake
th fix
DMD
#39071 02/21/02 08:59 PM
Yes it is an ATX oil cooler,no it wont handle engine oil pressure,not designed for it......
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
