Posts: 413 |
Just completed- The upside-down license plate mod !
Resonator is a 'pre-muffler' of sorts.. located between the cat and muffler on the V6 Contiques. Wish I hadnt done mine.
Posts: 1,732 |
Originally posted by Ridin Dirty: why would you remove your hoodliner? I think it's really there as a sound deadener. It is quite thick (at least mine is), so it would allow more air to pass through the engine bay. In the summer after driving, the hoodliner would be really hot, so I believe there is a heat soak issue here, too.
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 7,329 |
Originally posted by IRON MIKE: Who can forget the ol gut the main cat free mod :rolleyes:
I'm no fan but people seem to do it, Except that lowers performance...
Posts: 7,329 |
Originally posted by Ridin Dirty: why would you remove your hoodliner? Because it acts as a heat blanket making the engine bay even hotter. Very bad.
Posts: 107 |
How can you forget the throtle hang fix?
98 MTX V6 SE Sport KKM Mangnaflow muffler and res.
Posts: 79 |
What is the throttle hang fix? I'm new at all of this.
96 Pacifica Green GL Aftermarket JVC stereo White-Face HVAC Purple interior CTA Intake SVT Exhaust (coming soon) BNM White Face Gauges (coming soon)
Posts: 1,831 |
Clear corners...............
only if it is a 98 or newer
(others may be reading this)
Posts: 1,202 |
The hoodliner is there to act as a "fire-blanket" of sorts as well. If a fire breaks out in the engine compartment the plastic tabs melt and the hoodliner falls to try and put out the fire. At least someone told me that once..
Married the gal of my dreams 04.27.02  2K SVT Black/Midnight Blue #294 of 2150 DOB 10.29.99 kbucy@fbr.com ktigerj on aim A *few* Mods Best Time 14.942 at 93.98mph Car is now for sale - 14000
Posts: 23 |
I am going to polyeruthane the motor mounts, and put shorter screws in the throttle body butterfly plate. Cheap mods.
