I think I know what it is (emissions stuff of course) but my car is making this horribly annoying "mmmooooooooooovvvvvvvvvmmmmmm" noise when I start it up on cold mornings for a few seconds. My mechanic buddy said it had something to do with an intake air sensor needing lubrication, but I'm not sure.
Any clues? Thanks!
Black/Beige '99 SVT Build #482. Shaved emblems & door dingers
1
1
This is called moosing around here and there are plenty of threads started about this. The easiest way to find what your looking for is to do a SEARCH and you'll be set. There's just to many links for me to post right now.
Hope this helps. wink
Silver Frost 2000 SVT #1443 of 2150
Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals
Ventshield raingaurds, moonroof and hood bug deflectors
True Rev Induction Kit/ BAT Air Inlet Pipe
Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters
Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62.
Motorola Timeport HF car kit
Looking to increase performance!
http://photos.yahoo.com/hpick1
Future Mods waiting to be put on:
Lotek Guage Pod w/ volt, a/f ratio, and oil pressue.
Blue neon undercar kit
Aussie Bar w/ upgraded backing plate
Bullitt Fuel Door
Magnacore Wires
Ground Control Kit w/ Koni Struts
Very common. "Moosing." It isn't emission related, but a valve (Intake Air Control, IAC) that opens when the throttle body is shut. It gets dirty over time. There are 3 things you can try: 1) clean the IAC, 2) replace the IAC (this eventually worked for me after 1 failed), or 3) Throttle Hang Fix .
That's a moose not a cow :p , get to know the moose, as he will visit you often in cold weather. I'm hoping to clean out my iac this weekend if the weather is ok.
2000 Silver ZX3
1999 SVT Contour RIP 6/9/02
where is this IAC at ? i have this problem too but i didnt want to do the THfix because its rumored to rob power
-Speed Demon- Matt
Black 2000 Contour SE Sport (duratec/atx)
got body mods?
all show, better than stock go smile
"I might be crazy, but I'm not stupid"
speddmn.com
the BAT pipe gets rid of the moose too!
2000 SVT (silver)
#1529 of 2150
yeah...its modded
2
2
The only thing I had to do was the TH fix. I had my IAC replaced under warranty because of idle fluctuation, and it didn't help. The TH fix is by far the cheapest way to start(18 cents and 10 minutes of your time). Read the FAQ, and it will describe exactly how to do it. If it was easy enough for me to do, it sould be a breeze for you. Good luck! wink
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
Set me back $150 at the dealer. Probably should've done the TH fix instead.
Russ
1999 Red SVT #1194
"CART 99"
