Behind the a/c compressor is the best place to put the sending unit, but its not the easiest. Also you can put some Teflon tape on the threads to be sure you don't have any leaks. Just be sure you don't put any on the last few threads. That will allow the unit to be grounded on the block.
98 svt #3967/6535
BOD 10/13/97
itg air filter
air inlet pipe
south country strut tower brace
A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio
Replaced resonator w/Dynomax Bullet
