Posts: 134 |
Hey, I need some help. Where did you get your white/blue bulbs for your signals and fogs?
And How do I change the fog lights?
98 SVT Silver so NEW
Posts: 9,178 |
Originally posted by renn: Hey, I need some help. Where did you get your white/blue bulbs for your signals and fogs?
And How do I change the fog lights? I'm not Jared but, I got my Xenon park/blinker lights at a shop down here in Orem called Untouchables. They ran me about $10 a piece. If you want to meet up sometime and see them that would be cool with me.
Posts: 1,627 |
The whites I gave you or the ones on my car? The ones on my car I got all my headlights/fog lights from www.midnightmoose.com and my turn lights from www.autotoys.com (I think). Watch out those the fogs will melt your lenses and in some cases even your bumper. Ive been lucky enough to just have a bubble but everyone thats had them has had them melt in some way shape or form. So I wouldnt really recomend them. Im not sure where I got the ones I gave you, I think I got them from Godfathercustoms.com but not to sure. Watch out though there signal bulbs are crap. To change the fogs id wait for a nice clean warm day. Crank your wheel all the way to the left or right depending on the bulb you want to change. Get down on the ground with a flash light. Undo the 2 screws holding the splash gaurd to the fender gaurd underneath. (in some cases you can undo the two little access panels but I found this harder and a bigger pain. Then youll see the back of the housing. Just twist the bulb out of there change them and waa laa your gold. Crawl out brush your self off start up your car and crank the wheel to the opposite side. If you need any help id be happy to help you if you cant figure it out.
00 Black SVT #1545 Ground Control. Koni. 18" Konig Tantrum. More.
Posts: 134 |
Thanks man. I am going to give it a try.
I love lights on your car.
Thanks Colter...
Posts: 134 |
Hey, Which Bulbs will fit from midnightmoose.com for my signals?
Posts: 9,178 |
I think the park lights are 3157. I don't know what my bulbs are something different though. I can check and see if I can find the number
Posts: 134 |
Are you sure? They dont have any superwhite 3157's Do the 3156's work?
Posts: 9,178 |
I about 95% positive. Let me see what mine are. I went to Untouchables and the guy opened a couple packets to find out which ones would work.
Posts: 1,627 |
Anything 3*57 will work. I dont know about 315* I dont think so though. Im not sure I got mine from www.midnightmoose.com though.
