Page 8 of 13 1 2 6 7 8 9 10 12 13
1
1
Originally posted by Terry Haines:
Why then have Ford gone to a revised damper on all 2.5 V6 Duratecs if their isn't an issue?...
Not to dowmplay reliabilty improvements, but there are other considerations:
Montero Sport V6's are also equipped with dual-mass crankshaft pulley damper that helps quiet and smooth the engine
http://www.honda-newsletter.co.uk/sept2001/generation/
Achieving high levels of refinement has been a key priority in these latest Civic models and NVH measures include an engine undercover, thicker urethane foam insulation in the front bulkhead area, thicker floor mat insulators, and noise-absorbing felt backing on the fascia. The engine itself features a high-performance acoustic cover and a dual damper-type crank pulley, while a higher inertia flywheel further improves refinement levels.
Obvioulsy less noise also equals less vibes that the crank withstands, obviously you guys would know better if it was reliability or NVH that drove the duratec change.
"There is hard evidence though, of blown engines due to oiling failure"
Bradness, that was my question - what exactly is that evidence? I mean, how do you know it was oil related failure (as opposed to chronic effects on bearings by crank whip)??
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Once again, we have healthy disagreement. I can't comment on what the internals of an engine run without a damper and blown look like. Maybe Puppy is trying to say that it looks just like an oiling failure-that wasn't clear to me from the argument he put forth. However, I do know what a motor that has been starved for oil looks like when torn down.
Again, my experience with my 95, purchased new, with lots of miles has been no such failure! I'm talking about "real world" testing, not in a dyno cell. How many people have UDP's on their motors? If the stock damper is such a piece of crap and UDP's are sooo much worse, then..... Look at the available real world evidence and what do you see?
I'm not trying to sell anything or twist your minds. If you feel more comfortable replacing the single mode or UDP with a dual mode damper, do it! I, for one, remain unconvinced.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
Wonder how many qts of oil stay in the heads of the 3.0 Duratech?,how many Taurus 3.0 have failed with oil stravation?,funny as the oil system is the same?why put in a 3.0 when you will have the same problems as a 2.5? FWIW the duel mode Ford of Europe dampers are 'in the air'!!! confused
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Originally posted by ScottK:
... and seen a prototype Jag drive by wire system (they lost that work real quick when Ford got Jag) ...
Heh, I worked on the Ford Electronic Throttle Control manufacturing group when I was a co-op. smile
1
1
I was a GM Scholar, got 3 years at the University of Rochester plus summer internships compliemtns of the General smile If it weren't for the economy in '92 when I graduated (across the board hiring freeze) I'd probably be driving a GTP or some other quick GM sedan now.......
JVT Offline
Originally posted by L8 Apexing Aussie:
I have 3 more DM dampers for Sale. Starting price is $90 each, plus postage ($5). If I get more than 3 offers, I will allow people to up there bid by $5 until I have them sold.
NOTE: these are probably the last 3 I can get for a LONG time.
eBay
JB
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
WTF is ebay going to get you when they are not available in the USA?
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
JVT Offline
Huh?
JB
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
You pointed to Ebay......the ones being auctioned were from Aussie....I am lost her John...point me in the right direction.
Just call me Judge.
People suck.
