#303890 03/19/01 12:18 PM
Has any one had their springs replaced yet, due to coils breaking off?
I've had the front ones done, and yesterday I found a 4 inch piece of spring on the driveway. Looks like the rear left this time.
I'm still waiting on a Ford refund on the front springs. Anyone know if they are supposed to cover the rears as well?
#303891 03/19/01 03:48 PM
9
9
I broke a rear... I have extended warrenty so it was covered... I didn't know the put a "snow belt" warrenty on the front springs?
I don't think it was ford's fault that the rear broke... I drive hard (broke 2 in the old tempo, both rear), and have had alot of weight in the back
1995 V6 SE MTX
1998.5 CSVT
1963 Riley Elf/Saab 2.0L Turbo swap
Go to the Photoshop tutorial page
#303892 03/20/01 05:05 AM
Actually there is a problem with the Ford springs used on the Contours. (And many Ford products) Especially the 1995's. They are overly prone to corrosion, and as a result of a few years and some road salt they tend to break off quite frequently. When I had the front ones replaced, the shop that did it for me told me they have replaced more broken springs on Fords, than any other cars they've repaired. Apparently the springs are of very cheap quality.
Here is an article about corroding springs and Contours.
http://www.ottawacitizen.com/wheels/recalls/990226/2316182.html
#303893 03/23/01 01:06 AM
N
N
I'll be lowering my car this spring/summer and if my old springs from my 98' Mystique fit your car, your welcome to have them for a low low discounted price. I haven't had any problems with them yet.
Black 98' Merc Stique GS MTX Duratec
Cat-back 2.5" SS plumbing with Flowmaster 40 muffler
KKM True Rev induction
Eibach Lowering Springs
16" Fast 17 wheels with 225/50/16 Potenza RE910's
Code alarm with pager
20% tint on sides and 5% on back
Alpena Racing pedals
Painted calipers (black)
55W & 65W Xenon Headlamps
Mobil 1 Synthetic ATF with Ford FM
Clear Side Markers w/orange bulbs
Removed rear badging
"Park it, or put a porch on it!"
#303894 03/25/01 01:45 AM
They called me today. After 7 weeks. Told me spring replacement is for 4 cylinders only. Really have to wonder about these Ford guys. They should have known it was only for 4 cylinders right in the beginning, if that truly is the case.
#303895 03/25/01 01:47 AM
Let me know when the time comes. I'd be interested. I'll double check to see if the 98 Mystique springs are compatible with the 95 SE's.
Moderated by  Gerald_dup1, mbb41_dup1
