Posts: 70 |
Ok, perhaps I'm being paranoid here, but I just did the MTX Cocktail thing yesterday, and during the filling of the tranny, I had the car up on stands, both left and right, so the car was horizontally level, but tilting back. (I have no idea how any of you accessed the fill hole with the car completely flat on the ground.) Anyway, the transmission took the full 3 litres of Synthetic ATF and the 1/2 bottle of FM.
Now I'm wondering if it's overfilled, because I had the car tilted back and not level when filling the tranny? Need I be concerned, or should I just drive and not worry about it? Thanks.
Posts: 314 |
Mine took exactly 2.5L and 1/2 bottle MF. You may have overfilled.
Black 98' Merc Stique GS MTX Duratec
Cat-back 2.5" SS plumbing with Flowmaster 40 muffler KKM True Rev induction Eibach Lowering Springs 16" Fast 17 wheels with 225/50/16 Potenza RE910's Code alarm with pager 20% tint on sides and 5% on back Alpena Racing pedals Painted calipers (black) 55W & 65W Xenon Headlamps Mobil 1 Synthetic ATF with Ford FM Clear Side Markers w/orange bulbs Removed rear badging
"Park it, or put a porch on it!"
Posts: 70 |
Originally posted by Not Jap: Mine took exactly 2.5L and 1/2 bottle MF. You may have overfilled. The tranny feels ok. You think I should drain some out?
Posts: 314 |
I myself wouldn't worry too much unless I noticed something wrong.
Posts: 1,391 |
You have overfilled for sure.
just open the fill hole (on level ground) and let whatever comes out, come out.
Joe, 98 GL sport (V6 MTX)
Posts: 70 |
Originally posted by joe: You have overfilled for sure.
just open the fill hole (on level ground) and let whatever comes out, come out. Had the fill plug removed and let the excess drain out when I had my car in for the oil change. I think the tranny is even smoother now. (But perhaps it's in my head, cause I think it ought to be smoother with less pressure.) Probably about a 1/2 litre came out, so it likely was overfilled. Thanks for the help guys!
Posts: 22 |
I used 3&half qt redline + 2 0z fm , cant over fill a standerd , more fluid more positive shift , less noise .just dont do it on a atx
96 2.0 mtx kenwood deck & amp,mtx cr, boston acustics,12inch phonix gold 45sq feet vibration dampning/sound proofing 15%tint 98 rims ,fire gta's factory tack install k&n ,intake res removed accle thunder , ngk custom exsaust redline/fm , waterwetter , sy oil& stp svt mounts jet chip
Posts: 888 |
Originally posted by labelle: I used 3&half qt redline + 2 0z fm , cant over fill a standerd , more fluid more positive shift , less noise .just dont do it on a atx too much oil in a mtx will cause the gears to be too much in the oil... you then cause the gears to push more oil= more work needed. It will slow your car down, and waste gas.
