Posts: 149 |
I am having my F-head engine rebilt, I know, this is not a tour but, it is an engine Anyways, I would like to replace the head bolts and I wanted to know if Grade 8 bolts would work? If not, do I need to order some from ARP or somewhere else? Even after the rebuild this engine might only make like 70-80 HP. so, stress is not much of an issue. I hope :rolleyes:
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!! It's a chronic disease.
Posts: 5,805 |
Grade 8 will not work...use either stock head bolts or ARP if you have upgraded engine.Its wise NEVER to reuse head,rod or main cap bolts......
Posts: 149 |
Mark
