#37961 01/18/02 03:12 PM
Does anybody have any advice on how to install sub-frame connectors on a 98 SVT Contour? I have access to a lift, but it lifts the car by the frame. Are there any other lift points under the car? Any tips or problems you have run into would help. Thanks
Ground Control Coilovers
Koni Adjustable struts
Sub-frame connectors
Slotted rotors
Carbon Fibre pads
Stainless Steel Braided line
KKM Intake
Pro-Flow Mass-air Meter
22mm rear sway bar
Polyurethane motor mount inserts
#37962 01/18/02 03:46 PM
I've heard it might be better to install those with the weight of the car supported by the suspension... This means you need a something like an alignment lift with ramps...
Did you purchase the connectors from SHOShop? I'm considering this one myself...
#37963 01/18/02 04:18 PM
I had mine welded on the car while the car was on a frame lift. Now before you all scream bloody murder I did not have choice. It was my friends shop and I got the work done for free. I can't tell you if how I got them weld on made a difference because I have not driven a another car with sub-frame connectors. That being said the one thing I would recommend is to paint them before you get them weld on. The sub frame connecters are bare steel and will rust.
There is an added bonus! Now I jack my car on the subframe connector mounts which mean that I don't have to remove the side skirt jack point covers anymore.
#37964 01/18/02 07:11 PM
I got the sub-frames from SPMotorsports, but they got them from SHO. So its the same thing. I'll post another message when I get them installed as to whether they are worth it or not.
Slotted rotors
Carbon Fibre pads
KKM Intake
22mm rear sway bar
#37965 01/18/02 07:29 PM
I saw Jose97's car the other night and he has the SHOShop subframe connectors in there. Do paint them, cause they will rust otherwise! He said they made a big difference, but don't forget they are heavy!
#37966 01/18/02 10:10 PM
Does anyone have any pics of these installed?
'00 CSVT #570 - 3L
#37967 01/19/02 01:29 AM
00' SVT #915
Silver Frost
Done some stuff
_ _ _ _ _ _ _ _ _ _ _ _ _ _
#37968 01/19/02 04:47 PM
I have them on my car and you need to have them welded on with the car in a RAMP type lift.
The reason?
If you weld them on while your car is liftes by jack points, you going tobe welding you car's body to that felx position!!!!!! Making alightments almost impossible!
Lucky for me, I right within an hour drive to the Sho-Shop and had them installed.
My advice.... try finding a shop that has an alightment machine, (thats the ramp jack you need) so you can have you car's weight supported by the wheels, NOT by the frame.
But with all said I can really tell the diffrence in it. Love the turns even more now laugh
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
#37969 01/22/02 08:37 AM
0
0
The reason?
Like Chow said, DO NOT weld them on any other way other than on a drive-on ramp type lift!
You will not obtain the full potential of the connectors and possibly throw alignment out of whack.
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!!
It's a chronic disease.
